Unable to load IOS bootable file in Aironet 1310
Dear all,
I am using Cisco Aironet 1310G-A-K9-R
Radios for point to point communication. Actual Radio has come with IOS
firmware version 12.3, but we are trying to upgrade it with 12.4 10b
fireware, after we upgraded Firmware, we are able to open it in Internet
Explorer, but we are getting a home page with different options. though we
are able to telnet and configure it. So please send me a solution, how to
configure it back to its original condition.
In some Radios the IOS bootable file has got corrupted and we are unable to
log into the Internet Explorer, we were only log through Console port and we
are unable to reimage the Bootable image back. we are getting only
Bridge:
option....
please send me a reply for both the issues.
Thanks in advance
Sam
Silver
Re: Unable to load IOS bootable file in Aironet 1310
You can view a list of the contents of a file system before manipulating its contents. For example, before copying a new configuration file to Flash memory, you might want to verify that the file system does not already contain a configuration file with the same name. Similarly, before copying a Flash configuration file to another location, you might want to verify its filename for use in another command.like
dir [/all] [filesystem:][filename] -display Display a list of files on a file system.
show file system - display Display more information about each of the files on a file system.
show file descriptors - Display a list of open file descriptors. File descriptors are the internal representations of open files. You can use this command to see if another user has a file open.
Here is the URL for the Managing Firmware and Configurations
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_2_JA/configuration/guide/s32mfw.html#wp1002608
Thank you for your message and for the link, I have tried the process listed in the link and was able to reconfigure it back.
however, for the second issue I am still unable to reload the corrupted bootable IOS image. Can you please provide me solution for it.
Thanks in advance.
223
