Unable to see WPA/WPA2 SSID with Vista
I am installing a Cisco wireless network for a customer and they are unable to see the secured (WPA/WPA2) SSID's. They are running Vista on all of their workstations. I am running XP on my laptop and can see it fine and connect fine. When I change the SSID to be open with no authentication, they can see it and it comes right up. Figured that this might be a Vista issue, but that you may have seen it before. any help is appreciated.
1 REPLY
Bronze
Re: Unable to see WPA/WPA2 SSID with Vista
check out this bug:CSCsg56510
134
