Unified Access - 3850 Wireless / ISE Connection Delay
Hi Experts,
I currently have a customer problem. We use the 3850 switch as a mobility agent and a 5508 as mobility controller. For AAA we user ISE with profiling.
We run 802.1X in the wired and wireless enviroment (Access is 3850 only). In wireless we experience a delay on the first login of the day. So, when the client associates to the SSID it takes very long to get an IP Address. All following associations work fine.
This also happens on the guest (non 802.1X) SSID.
Do you have clue of the reason or where to start troubleshooting?
Best Regards
Michael
Everyone's tags (1)
VIP Purple
Hi Miichael,Have you enable
Hi Miichael,
Have you enable DHCP snooping on wireless user vlans on your 3850 ? It is a recommended feature.
Rasika
**** Pls rate all useful responses ****
Hi Rasika,not so far. But how
Hi Rasika,
not so far. But how does this affect the connection delay? Is the wired and wireless bahvior different regarding dhcp snooping?
I was also thinking if this has something to do with inital association. Maybe there is something wrong with the MC?
Best Regards
Michael
VIP Purple
As per Cisco's recommended
As per Cisco's recommended best practices, yes DHCP snooping is one of them.  I would enable it on your wireless user vlans & see if that makes any difference.
Here is what 5760 Best Practices Guide says,
Rasika
88
