Unplanned deletion of the VLAN interface
Hello everyone
Few days ago we had a planned change in our network to add a new backup link and add it to the BGP process on the router . but on doing that , the engineer decided to use an old port that was configured for VLAN 14 but wasn't being used , while , the VLAN itself , is trunked on this router through another switch and then goes out the main uplink to the rest of the network .
the problem is , once the guy deleted the config over this port ( including the part linking it to vlan14 ) , the main vlan 14 interfaces was also deleted !!
Anyone knows why did this happen ? is it a bug or something ?
sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(25)SEB4, R ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 15:47 by yenanh
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE SOFTWA RE (fc1)
r1.ako.corp uptime is 1 year, 51 weeks, 5 days, 19 hours, 25 minutes
System restarted at 20:34:44 NZ Wed Aug 23 2006
System image file is "flash:c3750-ipservices-mz.122-25.SEB4/c3750-ipservices-mz. 122-25.SEB4.bin"
cisco WS-C3750G-24TS (PowerPC405) processor (revision M0) with 118784K/12280K by tes of memory.
Processor board ID CAT0946Z3U5
Last reset from power-on
17 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:16:46:5B:E8:00
Motherboard assembly number : 73-7058-13
Power supply part number : 341-0045-01
Motherboard serial number : CAT094705DV
Power supply serial number : LIT093902PG
Model revision number : M0
Motherboard revision number : C0
Model number : WS-C3750G-24TS-E
System serial number : CAT0946Z3U5
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
1 28 WS-C3750G-24TS 12.2(25)SEB4 C3750-IPSERVICES-M
* 2 28 WS-C3750G-24TS 12.2(25)SEB4 C3750-IPSERVICES-M
Switch 01
Switch Uptime : 1 year, 51 weeks, 5 days, 19 hours, 12 minutes
Base ethernet MAC Address : 00:16:46:5B:E2:80
Motherboard serial number : CAT094705HK
Power supply serial number : LIT093902VX
System serial number : CAT0946Z3T2
Configuration register is 0xF
the show ver rsults are below .
1 REPLY
Bronze
Re: Unplanned deletion of the VLAN interface
96
