04-01-2014 03:08 PM - edited 07-05-2021 12:35 AM
I have just deployed a new 3850 with the integrated wireless controller and 2 2600i APs. Before joining the APs to the controller, I upgraded them to the latest LWAPP image. It appears that they were downgraded when joining the controller the first time. Is there a way to install the latest version of LWAPP software back to the APs from the 3850 controller?
Solved! Go to Solution.
04-01-2014 03:19 PM
Hi Andrew,
LAP always download the image run on a WLC (in this case 3850). So no point upgrade LAP independantly as it will always sync with image run on the controller it joins.
In this case you can upgrade 3850 to 3.3.2 (which is the latest image as of today) if you are not already running that code
Rasika
**** Pls rate all useful resposnes ****
04-01-2014 03:19 PM
Hi Andrew,
Rasika
