Upgrade Cisco Aironet 3502i to Lightweight
Hi there,
Anyone tried to upgrade C3502i to Lightweight? I failed to upgrade using Upgrade tool v3.4. The error message is "AP model is not supported" . Pls advise how can I upgrade it?
Thanks and appreciate your advice!
Hall of Fame Super Silver
Re: Upgrade Cisco Aironet 3502i to Lightweight
The 3502's are already lightweight.
Sent from my iPhone
-Scott
Yes, initially it was. But i converted it to Autonoumous and now I need to convert it back to LW
You can't use the tool! Take a look at this doc.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
Sent from my iPhone
-Scott
Thanks for your quick reply. I knew that I cannot use that tool. Could you suggest the solution to do it?
it's the same as you I'd to convert it to autonomous. Just download the recovery image and perform the same steps. If you console into the ap and hold the mode button down then power the ap up, while holding the mode button for 20 seconds and releasing the button, you will see from the output what filename you need to rename the recovery image.
You will tftp the same as you did when you converted that to autonomous.
-Scott
Follow this, but use the recovery image:
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
-Scott
Appreciate your instruction. I will try once I have the AP. I dont have it right now.
Cheers!
Here is an older post which explains another way to convert the AP. It's for a different model, but same procedure.
https://supportforums.cisco.com/message/1266116#1266116
Sent from my iPhone
-Scott
Hi Nhat, What is the version of IOS autonomous del AP?
1736
