Upgrade of AP1200 to IOS failed
After upgrading th AP1200 to IOS with the conversion image the unit fails to start, when conencting a terminal to the consoleport you got this message:
Testing DRAM...
(press <esc> to bypass)
DRAM OK
Power-on reset.
Copyright 1996-2000 Cisco Systems, Inc.
Copyright 1984-2000 Wind River Systems, Inc.
System ID: 000B5FE7B971
Motherboard: IBM405 200MHz, 8192KB FLASH, 16384KB DRAM, Revision 04
Bootstrap Ver. 1.00: FLASH, CRC 1C914641 (OK)
Initialization: OK
Memory Bank total used left
DRAM 16742624 0 16742624
Config 524288 0 524288
FLASH 7602176 0 7602176
Memory Bank:File address size encoding type flags
Type '=3D' for main menu.
c -- Copy file
f -- File dir
l -- downLoad file into DRAM
u -- Upload file
p -- xfer Protocol
n -- coNsole
r -- Run
s -- System info.
Looks like the image was not saved into the flashmemory
Bronze
Re: Upgrade of AP1200 to IOS failed
If you have a backup copy of the following files
EnterpriseAP Sys xx
EnterpriseAP Web xx
Inflate Ver. xx
350 Series FW xx
AIR-RM20 FW xx
AP Installation Key
AWC_ConfigDB
You can try to xmodem transfer them into Flash of AP . If you do not have a backup copy but have
the similar AP you can copy those file to you PC using xmodem and then transfer above files to
failed AP that had its flash erased from the failed VX-IOS upgrade process . Then , copy the AP
Installation Key from DRAM into Config , copy the AWC_ConfigDB from DRAM into Config and restart the
AP
Try the VX-IOS upgrade process again as per the Cisco Documentation provided with the upgrade
image.
If you do not have backup or above procedure fail, then replacement would be the only solution.
I tried copy the upgrade image to DRAM with XMODEM and then copied the four files that was extracted from this file into flash and then rebooted the AP. Then the upgrade process started and the AP come up as an IOS AP1200.
I did not copy any installation key to the AP, are that file needed in IOS mode?
I also have a dead one like this. Can i copy the files from a Aironet 350 Series to 1200?
Installation Key is unique for every device, there are crtical functions associated to it and once lost the only option left is to request Cisco to RMA that device.
Raja
All the entries that you see in the DRAM or config should be copied to flash, the Installation key or VAR key should always be copied, loosing the installtion key will lead damaging the device completely.
Also every key is unique, key for one device will not work on another.
467
