You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Upgrade path for a 1200 series wireless access point
I have a AIR-AP1231G-A-K9  Wireless access point that is current running ISO 12.2(15)AJ. My question is this. Does anybody know if there's an ISO upgrade for the unit?  I looked on the CISCO site and could not find any info about and upgrade path for this ISO release.
          Reggie
  • Other Wireless - Mobility Subjects
Gold
Re: Upgrade path for a 1200 series wireless access point
There really isn't any interim upgrades that would be required.  The  format of the config changes in version 12.3(4)JA if I remember  correctly.  All this really means is if you upgrade past this version you will not be able to downgrade below this version without having to reconfigure your SSIDs.
So we can upgrade to 12.3(8)JA or higher? Would there be any reason not to upgrade? The current revision works fine so would it be best just to stay with this version?
          Reggie
Are you still facing this issue?
thanks,
Vinay
Thanks & Regards
194
