Upgrade WLC2106
lldemeyer
I tried to upgrade a brandnew WLC2106 from V4.0.206 to V4.0.217 using the file
AIR-WLC2006-K9-4-0-217-0.aes and once the file is downloaded I receive an error that this is not the correct image for the 2106 . On CCO I do not find specific files for 2106 . Any clues ?
Thanks.
owensm
You probobably encountered the error because there's actually a seperate version for the 2106. See the link to download the code?
http://www.cisco.com/cgi-bin/tablebuild.pl/2100_series_Wireless_LAN_controller
owensm
Thanks a lot for the right pointer! Do you have inside information? Anyway I just did a recheck and using the normal way to locate the images on CCO via the standalone WLC directory I do not find a directory for the 2100 , only for 2000,4100,4400 ...
