Upgraded AP1231G still has old MGMT interface - issues connecting
bmeegan
Hi, I have a stand alone AP (Air-AP1231G-E-K9) which is not lightweight, or connected to a WLC, its a simple config with a Radio and Management interface.
The IOS was previously running c1200-k9w7-mx.122-13.JA1, so I upgraded the IOS to c1200-k9w7-mx.123-8.JA2 (Similar to some other working AP's I have), however there are problems with clients connecting to the AP, they doesn't see the AP.The configs on working and non-working AP's are identical (apart from IP's) and the only difference I can find is the web management interface screen which is different.There are more options on the newer working AP's with the new version of code and newer management interface,,, the AP I've upgraded has an older looking web management interface.
If i want to upgrade the files on the new AP to have the new Management interface over http working, what do I need to do, where do I get the files from, and what do I need to replace on the new AP along with the latest IOS to be able to configue this and hopefully get it working?
Brian
Stephen Rodriguez
It all should be upgraded from the one IOS load. You could try uploading the newer load and see if it fixes. I generally prefer to do these from the CLI:
archive download-sw /f /o tftp:///
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hi Steve,
Thanks for that,so there must be another problem if the web mgmt interface did not upgrade during the new ios install (which was through the cli).is there a quick way to flush the old code + other directories on the AP's so I can try the IOS upgrade again from my tftp server?
Brian
the command I gave you, clears the IOS from memory, and then puts the new image on,
HTH,
Steve
