Upgrading from WLC 4402-50 to WLC 5508-250
I am planning to upgrade my WLC 4402-50 (HA) to WLC 5508-250 (HA). I also have some really old 1020 Access points that I will be replacing with 1142's. Once I have completed the upgrade to the 5508s, I will repurpose the 4402's as Mobile Anchor controllers to support Guest Wireless.
Does anyone have any actual experience with this sort of upgrade? Any practical suggestions or ideas??
1 REPLY
Re: Upgrading from WLC 4402-50 to WLC 5508-250
Are you still facing this issue? if yes try checking the link if that helps
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a008064a991.shtml
thanks,
Vinay
Thanks & Regards
1150
