02-13-2012 05:33 PM - edited 07-03-2021 09:34 PM
I plan on upgrading WCS from version 6.0.181.0 to 7.0230.0
Is there any reason not to or concerns?
02-14-2012 06:00 PM
so long as you can download the code I see no reason you shouldn't. So long as WCS>= WLC you should be fine.
And the 7.0.230.0 gives you the ability to migrate your data from WCS -NCS
Steve
02-14-2012 06:03 PM
As Steve pointed out you should be fine. Here is a WLC and WCS software matrix if you want that warm and fuzzy ..
