01-06-2012 06:19 AM - edited 07-03-2021 09:20 PM
Hello
We are trying to refresh the current IOS in our 3502i APs from version E to C. The instructions we were given were as follows:
AP#capwap ap ip address <IP address> <subnet mask>
archive download-sw /overwrite tftp://a.a.a.a/xxxxxxxx.xxx (xxxxxx if the firmware file name) (a.a.a.a is the PC with TFTP server IP)
The first problem encountered is that the 'archive' command doesnt seem to exist on the 3502i. We also tried the 'upgrade' command but get a response that the command is not recognised (even though it is in the list of commands).
We then based our attempts on the instructions in the following link:
http://samswireless.blogspot.com/2011/01/surveying-with-3502-followup-post.htmlhttp://samswireless.blogspot.com/
However when it gets to step 3 we get the following error:
[process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap3g1-k9w7-tar.default
examining image...
%Error opening tftp://255.255.255.255/ap3g1-k9w7-tar.default (connection timed out)
ap: ]
I cannot ping the AP from the PC when in this mode. The IP address on the PC is 10.0.0.2 /24.
What am I doing wrong? Please help!
Amy
Solved! Go to Solution.
01-06-2012 07:42 AM
Amy,
The ap will pull its code from the WLC so that it is on the correct image. As for the regulatory domain, the E to C, this can't be changed, it's a cookie written into,the EPROM in the AP
01-06-2012 07:43 AM
The only code you can put on these is the rcv or recovery code. You will not be able to change the country code because this is set from the factory. If you need an AIR-CAP3502I-C-K9, then you will need to rma the other ap for the one you require. This ap is a lightweight ap and requires a wlc.
01-06-2012 06:47 AM
Amy,
Those AP's are light weight. If you are trying to add them to a wlc, you can add the country domain on the wlc. You can't change the country domain though from the AP.
Scott Fella
Sent from my iPhone
01-06-2012 06:58 AM
Hi Scott
Thanks for the response. Is it not possible to put a different IOS code on these devices? The AP does attempt to open the default file but there's just not a connection to the PC after holding down the mode button while powering up.
Amy
01-06-2012 07:42 AM
Amy,
01-06-2012 07:43 AM
01-06-2012 07:49 AM
OK, thank you both for the help and explanation. We'll RMA the devices. Thanks
01-06-2012 08:38 AM
RMA through Cisco, is only going to get you the same AP that you already have.. You would be better served to go back to the VAR that you got the AP from, and have the, get you the correct ones.
