Using AIR-LAP1252 as AIR-AP1252
     Hi, all
               Does anyone know if I can just upgrade/replace IOS on AIR-LAP1252AG-A-K9 to be used as AIR-AP1252AG-A-K9 ?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Using AIR-LAP1252 as AIR-AP1252
Yes you can.  If you incorrectly purchased an AP with autonomous IOS (aIOS) when it should be the controller based (or vice versa), it's as easy as downloading the correct firmware, change the boot parameters and rebooting the AP.
It doesn't matter.  What matters most is the firmware you are using.
Thanks, leolaohoo
Does it mean that I can't just replace IOS?
Are functions restricted by firmware?
Yes, it is exactly my case. Returing wrong models will take a while. If both hardwares are the same I will just change software. I was afraid that Cisco won't allow users to do that.  Thank you so much for your time and info.
Can you rate my post or mark this thread as "Answered"?
Yes, of course; as soon as I get access to my computer. I don't know if I can do so by replying from BB.
Thank you very much.
My hats off to "leolaohoo"
FYI for others:
Following instruction is quoted from http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Set the timeout value on the TFTP server to 30 seconds.
Step 4 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View; then uncheck the Hide extensions for known file types check box.
Step 5 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, c1240-k9w7-tar.default for a 1240 series access point, and c1250-k9w7-tar.default for a 1250 series access point.
Step 6 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 7 Disconnect power from the access point.
Step 8 Press and hold MODE while you reconnect power to the access point.
Step 9 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 10 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 11 After the access point reboots, reconfigure it using the GUI or the CLI.
3360
