using aironet 340 AP with planet wireless lan cards
I'm having problem with the above configuration, has anybody encountered this problem?
1 REPLY
Re: using aironet 340 AP with planet wireless lan cards
Not a lot of details there, but a couple quick pointers. Make sure the AP is running at least 11.07 (preferably 11.10T), and that you have Aironet extensions turned off. The proprietary extensions are on by default, and are designed to optimize performance in Cisco-to-Cisco deployments. They should be shut off in Cisco-to-non-Cisco deployments. Also, make sure that you have the latest/greatest drivers and/or firmware from planet or whoever the other manufacturer is.
158
