Using aironet Survey results for airspace deployment
I have completed a site survey using the Aironet AP 350. I am now considering implementing the Airspace 1000 AP and their switch solution.
Can the survey results be used with some degree of confidence to determine number and placement of these new APs?
1 REPLY
Re: Using aironet Survey results for airspace deployment
It depends on the antennas used with the 350. If you used rubber duckies you can pretty much be assured that the 1000 will cover the area. If you used higher gain antennas it may not, it all depends on the antenna.
109
