Hi All
I work in the education sector & are looking at implementing a campus solution using the Aironet 1200 series access point.
School One: Site One
We currently have a 2621 router feeding a 2mb sycro broadband link into a primary school, Within the school we have 2 seperate VLAN's one for curriculum & one for admin traffic, they are broken out from the router using a 2950-12 port one is the trunk port to the router then 1st 5 ports are admin / second 5 ports are curriculum.
School1 Site2:
Standard Cat5 wired network, with both admin & curriculum IP ranges on the same wire. Would like to put a 1200 access point here and another 1200 access point at site one & have it carry both IP ranges too & from site1 where the broadband link is located.
Question? does the 1200 series act as a trunk across the wireless link & would I get away with one access point at each end or would I require an acess point per IP range, Site 2 has no cisco switches, it only has a dlink std switch, would ideally like to plug in and configure the access points & all would work, have read the cisco config guide, but seem to be having a bad day as it's not going in!!
Any help or guidance would be great!
Thanks Trev
