Verifying Radio model in AP
Hi guys, just one quick question: Is there a way to see the APs radio models from the CLI? Because im trying to see if the radios are compatible with LWAPP. I know that with the convertion tool the job can be done, but I want to know for sure before atempting to do the convertion.
thanks in advance!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Verifying Radio model in AP
Hi Omar,
I believe the command 'show controllers' should do the trick.
Hope this helps!
Rob
Hi Omar,
Hope this helps!
Rob
Thanks! problem solved
The conversion tool does it this way:
show controller | include Radio AIR
The strings it accepts are "AIR-" followed by RM21A, RM22A, AP1131A, AP1131G, MP21G or MP31G (on the 1240 or 1250, the other units it does no check for radio type presumably because they are all supported/integrated)
134
