VLAN configuration of LAP in H-REAP WLC Setup
I have a setup configured fairly simple, I think. We have a 4402 WLC at our corporate office. We also have 6 1131's split into two deployments at different offices. We have a common SSID structure across all of them (corporate and guest). Corporate works properly authenticating against Active Directory, and guest authenticates properly via the guest database. The thing I cannot get my mind around is the proper method for configuring these two SSID's to be on separate VLAN's. If it were all local, I think I'd have no problems. Do I need to configure a virtual interface on the controller? Do I need a separate one for each office? The VLAN won't exist in the corporate office (unless it needs to). My goal is to isolate guest access into it's own subnet and run it straight out to the Internet without touching the local satellite network. Thanks!
Sean
Re: VLAN configuration of LAP in H-REAP WLC Setup
Ok, think I figured it out. I changed the VLAN mappings via each AP edit page and all seems well. Originally I was going to try and push the VLAN configurations for both offices via the "guest" WLAN policy, which is where I think my confusion arose. By doing that, I needed to assign the configuration through an Interface (I'm guessing). If anyone has a better suggestion, please let me know. Thanks!
I have a question to ask!
are you using H-REAP??
249
