09-15-2009 03:31 PM - edited 07-03-2021 06:03 PM
Hello guys
I need implement Vlan in network where i have a cisco 350 series WGB, cisco 1300 series Access Point/Bridge and Cisco 1200 series Access Point/Bridge.
My wireless network schema illustrated in a NetWork Description.vsd file(Microsoft Visio File)
All devices configurations and versions files attached.
What can you say about this? When i started reconfigure network, it faced problems.
Please help to understand.
09-15-2009 03:35 PM
09-16-2009 04:52 AM
Hi Osman,
Were the workgroup bridges all working prior to the VLAN configuration change?
09-16-2009 11:00 AM
Hello jeff.kish
Yes, working prior change!
09-16-2009 01:28 PM
Osman,
Try running the following config script:
conf t
int dot0.2
bridge-group 2
int dot0.3
bridge-group 3
int fa0.2
bridge-group 2
int fa0.3
bridge-group 3
Cisco APs use the subinterfaces to represent each VLAN, which you have correctly configured. But to link the radio subinterfaces to the Ethernet subinterfaces, a bridge-group is required on each. You have bridge-group 1 configured on your native VLAN, which is correct.
Try that and hopefully you'll be up and working again.
