Vpn between PIX and iPaq
Does anyone tried to establish a connection with iPaq with movian vpn client and pix?
I succeed in establishing the connection but the client say that Ipsec driver is disabled and then packets to inside network not passes.
Please help me.
Re: Vpn between PIX and iPaq
Have got the same problem I assume, tried with my config and a Cisco VPN Client and everything works fine. Using Movian I am not successful.
I get authenticated application closes (as it should) but I do not get a IP Address.
HI
What i know is that movian only supports vpn connections to a vpn concentrator not to a pix! so i hope that movian is working in near furture on pix fw. PLEASE
bernhard
Hi, thanx for your post.
I resolved this issue, I opened a support case to movian that has sent to me documentation for configuring PIX. But my problem was that the movian client must be installed on main memory of the iPaq and not to compact flash.
If you want I can give you the documentation for configuring PIX.
Let me know,
Thanx
Hi Nicola
Yes please send me the docs for configureing the pix to fieglmueller@nts.at
thx
Bernahrd
I've the same problem.
Could you send me too the PIX configuration???
Thanks a lot!!!
(bubani@vem.com)
138
