07-08-2013 04:01 AM - edited 07-04-2021 12:22 AM
I've a question about vWLC instalation, has someone already installed it on Amazon AWS?
is it officially supported by Cisco?
Thanks in advance
Stefano
07-08-2013 04:51 AM
You need to look the see if Airwave support the vWLC. I would think it would since it just uses snmp. You just wouldn't get all the same features as if you were to use Prime Infrastructure.
07-08-2013 11:57 PM
you can install vWLC on Amazon AWS because you can import Virtual Machine on AWS which you created on VMware by using VM import/Export tool. For more detail about this tool and how you import the VM machine please follow the below link
02-03-2016 11:53 AM
Hello Stefano.
After 3 years since your initial post, seems that this is still a difficult question to be answered.
I've searched at many foruns but haven't found anything usefull. Yesterday I tried to migrate a vWLC 8.2.100.0 to our Amazon EC2, but no success at all.
Were you able to migrate your vWLC to Amazon?
Best regards,
Fabio.
08-01-2017 09:20 AM
hi,
vWLC on AWS is supported now on version 8.5.
Release Notes:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85.html
Config Guide:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/vWLC-on-AWS.html
Rui
