vWLC problem
Hi, please help with this strange problem
problem with Virtual Machine which Cisco Virtual WLC installed. Virtual Machine files were damaged and the system was not start normally. We have had to reinstall the WLC to new, but after installation impossible to import current license to new one
here is some logs:
(Cisco Controller) >license install ?
<url>          tftp://<server ip>/<path>/<filename>
(Cisco Controller) >license install tftp://192.168.1.136/93RT2LKUQQG_20130524070xx090.lic
Transfering licenses from tftp://192.168.1.136/93RT2LKUQQG_20130524070xx8090.lic
0/2 licenses were successfully installed
0/2 licenses were existing licenses
2/2 licenses were failed to install
Failed license installation at index:0 : UDI in license line does not match with the local udi
        Failed license installation at index:1 : UDI in license line does not match with the loca
so, i need to rehost license to new uid of wlc,
To rehost this license i used cisco.com/go/license
to registrate my vWLC i need LICENSE CREDENTIALS but,
when i use command on wlc license credentials save /tftp/ i have a problem
(Cisco Controller) >license save credential tftp://192.168.1.136/93RT2LKUQQG_201305240704358090.lic
Transfering licenses to tftp://192.168.1.136/93RT2LKUQQG_201305240704358090.lic
Failed to transfer the file
Local file /tmp/license.upd not found!
i cant understand what licence.upd file wlc need to send license credentials to tftp
PLEASE HELP WITH THIS URGENT PROBLELM
Everyone's tags (1)
Hall of Fame Super Silver
Re: vWLC problem
You need to open a TAC case and have them generate a new license file for you. You can use the same one, especially if you rebuilt the VM.
-Scott
Hall of Fame Super Gold
vWLC problem
Duplicate post.
Kamran,
This is your THIRD duplicate post.  I've already requested you to refrain from making multiple post of the same issue because it will confuse anyone.
Re: vWLC problem
sorry, guys my bad, so there is no way to rehost this license?
Re: vWLC problem
Delete the last two threads and return to your original thread.
Besides, I have no idea what answers YOU WANT TO HEAR.  There's already three people (Martin Wisely, me and Scott Fella) who's pointed to you the RIGHT METHOD of re-hosting your license but you continue to create duplicate threads.
1540
