Wall Mounting a 1250
jpolczyn
Has anyone looked into wall-mounting an Aironet 1250? We do not have ceilings in most locations which we can hang APs or antennas from, so I'm at a loss for how exactly we're going to use the 1250.
Hi Jeff,
Sorry about that, I took this literally :)
I think you can mitigate the Radiation Pattern question;
For the 2.4GHz Radio instead of using;
AIR-ANT2422DG-R non-articulated dipole Gain (dBi) 2.2
You could use;
AIR-ANT4941 **articulating dipole Gain (dBi) 2.2
For the 5.0GHz Radio instead of using;
AIR-ANT5135DG-R non-articulated Gain (dBi) 3.5
You could use;
AIR-ANT5135D-R **articulating dipole Gain (dBi) 3.5
From this excellent Guide;
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c1.html#wp1050183
You might also try the new antennas being introduced with the Cisco Aironet 1250 Series.
AIR-ANT2430V-R=
2.4-GHz 3 dBi Triple Omni Antenna *3 RP-TNC
AIR-ANT5140V-R=
5-GHz 4 dBi Triple Omni Antenna *3 RP-TNC
From this good Q & A;
http://www.cisco.com/en/US/netsol/ns767/netqa0900aecd806b7c82.html
Hope this helps!
Rob
Rob Huffman
Hi Jeff,
The 1250 can be Wall Mounted and does ship with the proper bracket for Ceiling or Wall Mounting;
AIR-AP1250MNTGKIT = AP1250 Access Point Ceiling/Wall Mount Bracket Kit
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6973/ps8382/product_data_sheet0900aecd806b7c6d.html
This doc shows the method for Wall Mounting and gives a nice Step by Step;
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c2.html#wp1095490
Hope this helps!
Rob
If I use the AIR-ANT2422DG-R antennas and mount the access point on the wall, doesn't this result in a radiation pattern which is perpendicular to the floor?
I guess my question is more about how to mount the AP to a wall *and* get a good radiation pattern out of the antennas, not about how to mount the AP to the wall.
Hi Jeff,
You could use;
You could use;
AIR-ANT2430V-R=
AIR-ANT5140V-R=
Hope this helps!
Rob
That first guide is just what I needed. I couldn't find any documentation that said the 4941s were supported.
I am considering working with our enclosure manufacturer to design an enclosure which would allow us to mount the 2430 and/or 5140 to the enclosure. Being able to use the articulating antennas without running into potential FCC Part 93 violations is a relief.
