Want to avoid Clients to connect to Wbridge1310 when root
i have implemented Wireless bridges between buildings , but i do not want that wireless clients can connect to the bridges configured as :role = root
as they are used only for infrastructure. I cant find infos on doc.can you help???
Re: Want to avoid Clients to connect to Wbridge1310 when root
Are you having problems with this? I bellieve you must set the role to Root with clients to make it possible. Anyway if you use proper security and encryption between the bridges you shouldt worry too much. You can now use WPA2 on the 1310 bridges. Also turn off ssid broadcast to avoid XP users see your network.
thanks. i have added the aes and WPA.
99
