WBG - HREAP
Hi, is it possible to combine(connect) autonomous AP in WGB mode with LAP in HREAP mode?
David
Hall of Fame Super Silver
Re: WBG - HREAP
I don't see why that wouldn't work for you... The WGB as long as it has connectivity to an ap should be able to bridge traffic back to the LAN. If you are doing local switching, then it's as if you have an automous ap. Are you having problems connecting the WGB to an hreap ap?
-Scott
Re: WBG - HREAP
I read in some sources that this does not work together so I just wanted to be sure before implementation. Thanks.
230
