WCS 5.0.56.0 - Where is AP-Groups VLAN feature?
I have 4 AP Groups (WLC: WLANs/Advanced/AP Groups VLAN) setup to limit what SSIDs each AP serves. These all show up as mismatches in WCS. I cant find any template available to configure these in WCS nor can I "Refresh Controller Values" to fix it. Any ideas? Is this a feature they forgot in WCS?
Versions: WCS:5.0.56.0 & WLC:5.0.148.0
Re: WCS 5.0.56.0 - Where is AP-Groups VLAN feature?
Yes, that's strange. You can configure an AP template so that APs a re part of the AP group VLAN, but the group itself doesn't show anymore in the controller templates. You can still configure it on each controller individually.
When auditing a controller (config controllers, select the one to audit -> audit now / Go), I can still see refresh controller values or restore WCS values..
hth
J
In WCS,there is no template option available to configure AP group vlan.But you can configure via WCS:
1)GO TO configure>controllers.click controller name link.
2)CLICK WLAN on left hand side.YOU WILL FIND AP group vlan.
3)Now configure AP group vlan-by adding group and select ssid want to serve for each vlan.
This will save directly to wlc.
I hope this will resolve your problem.
Kannan
Bronze
Hey folks,
Please correct me if I'm wrong, but doesn't AP Groups VLAN simply re-map the interface of the SSID from the defualt interface definition under the WLAN? I don't believe it restricts what SSIDs/WLANs are advertized by the Access Point - this has to be performed at the AP or via an AP Template. Is this a new feature of APG in 5.0?
Thanks for any clarification,
--Bruce Johnsom
You are right Bruce, the issue described in this thread is a combination of WLAN override, to decide which SSID is advertized by an AP, and AP group VLAN, to decide which interface / which VLAN tag traffic comming from a given SSID on a given AP will receive...
Bronze
Thanks Jerome,
Oh well. It would be nice to have WLAN override avaialble in a named-group function. Glad I wasn't missing out anyway.
--Bruce Johnson
464
