WCS 5.1.151 create ACL Security Template
I created some ACS templates in WCS 5.1.151, when I view them in WLC 4.2.130 I see errors like Protocol = IP on IP or Protocol = 255 and the ACLs don't work.
Silver
Re: WCS 5.1.151 create ACL Security Template
Follow the instructions in these sections to apply ACLs using the controller GUI:
Applying an Access Control List to an Interface
Applying an Access Control List to the Controller CPU
Applying an Access Control List to a WLAN
Applying a Preauthentication Access Control List to a WLAN
Here is the URL for the configurationi ACL for the WLC it may help you
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42sol.html#wp1104164
Creating ACLs in the Controller GUI has no problems, however we'd rather configure WCS templates and push them to Controllers to reduce labor and assure a consistent configuration across all WLCs.
Community Member
I am seeing this issue also.
Apply an ACL template to a controller from WCS. The protocol ANY is translated to "other 255". The ACL does not function for any protocol at this point. Manually update to protocol any on the controller and the ACL works properly.
I also noticed some inconsistencies on ACL sequencing but haven't narrowed those down.
I opened a TAC case but haven't gotten a answer. I would encourage you to do the same. I spent 2 days troubleshooting this!
Community Member
I did.
What version WCS are you running? I am using 5.1.64.0.
WCS = 5.1.64.0 and WLC-4404 = 4.2.130.0
Community Member
My controllers are WLC-4402 and they are running 5.1.151.0.
Here is some bugs that might be our problem.
CSCsr66296
CSCsr68838
549
