WCS 5.1 (Windows) fails in opening the page under Monitor->Security
f-genovese
Hi everyone!
Did anyone experience this issue?
The page appears empty on the right but I can see the tab with the alarms on the left.
dennischolmes
Level 7
Level 7
Runs fine on my box. Do you have any activex settings disabled?
Hi Dennis!
I'll have a check tomorrow, but that is the only page that experieces this issue: is it possible?
I'll make you know and thank you for your advise.
I have made a check but activex are enable.
The error message is :
Tag 'insert' can't insert page '/pages/monitor/switch/securitySummary.jsp'. Check if it exists. For input string: "79,46"
Sounds like a Bug. Id call TAC.
