Community Member
WCS AP Templates help. Vlan Override Issue
Hi all,
WCS ver 5.2.110.0
When I create a LWAP template, to apply a WLAN override to all my APs, the WLAN I'm looking for is not in the list. Previous WLANs are listed, that are no longer resident on the WLC4404. The current WLAN configured in the WLC does not show up in the list.
I've removed and re-added the WLC a few times to no avail.
Anyone with WCS experience ever see this issue?
1 REPLY
Hall of Fame Super Red
Re: WCS AP Templates help. Vlan Override Issue
Hi Wayne,
One thing to consider is that is WLC 5.x versions, WLAN Override has been replaced with the "AP Groups" feature;
Creating Access Point Groups
After all access points have joined the controller, you can create up to 150 access point groups and assign up to 16 WLANs to each group. Each access point advertises only the enabled WLANs that belong to its access point group. The access point does not advertise disabled WLANs in its access point group or WLANs that belong to another group.
http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52wlan.html#wp1128591
Hope this helps!
Rob
137
