WCS AP Templates
I am looking to use the AP templates to apply WLAN override on some of my AP's. Is there a way to run a report to verify where the template/wlan override is applied. Also after you apply a template how do you unapply the template?
1 REPLY
Bronze
Re: WCS AP Templates
To make modifications to an existing template, select the appropriate template link listed in the Template Name column. The WLAN Template > Selected Template appears. The screens that appear for creating a new template and the existing template are identical except that the existing template screen shows its existing configuration and its Profile and SSID values are fixed and cannot be modified.
Follow the steps given in below URL to add a new WLAN template or make modifications to an existing WLAN template.
http://www.cisco.com/en/US/docs/wireless/wcs/4.0/configuration/guide/wcstemp.html#wp1071033
133
