Community Member
WCS Import existing WLAN on Controller
We have a couple of controllers that were configured and running now we have added WCS and added the existing controllers.
We created a template for a new WLAN and then noticed that existing WLAN's and interfaces were not imported into WCS.
Is there anyway to import the existing info into WCS?
1 REPLY
Discovering Templates from Controllers
When prompted, WCS can search for associated templates for a controller and show the results.
Step 1 Choose Configure > Controller.
Step 2 Choose a desired controller by clicking the check box in front of the IP Address column.
Step 3 From the Select a command drop-down menu, choose Discover Templates from Controller and click Go.
A warning message confirms that the template discovery refreshes the configuration from the controller first.
The results page shows the template name, number, and template type.
You can also just do a refresh config from the WLC, and overright what's not on the WCS.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
285
