WCS MAPS quality are not good
I'm having weird problem with the MAPS quality... Why does the MAPS are displaying with a different quality on different machine?
For example, i do have a Windows XP machine with SP2 running IE 7 & the latest firefox release that is displaying the MAPS under
WCS with a bad quality.
I have a second machine running Windows 7 with IE 8 and have no problem displaying the maps under WCS.
The quality is good & i have more details..lines are smoother.
Both machine are connecting to the same WCS server. I have tried WCS 6.0.132 & 6.0.181 and i have the same
results.
Do you have a clue? Does the resolution makes a difference? Operating system? other?
Re: WCS MAPS quality are not good
Try it with Google Chrome. I've seemed to have better luck with that over IE. Next, WCS does use up a bunch of your computer's ponies and I've never tested with different OS's and computers (as I just use the dinosaur I was given at work), but I figure Cisco does add some logic to run WCS at a performance level suitable on your comp.
You can change the display setting, The minimum screen resolution that is recommended  for both WCS and Navigator use is 1024 x 768 pixels.
232
