WCS Problems
remco.gussen
I'm experiencing problems with WCS. After the installation i want to start the WCS program. An error occurs all the time:
Starting WCS
Cannot run with the current schema. Exiting.
Apache server is already stopped.
Failed to start WCS server.
Is this a known problem and what can i do with it ?
Gr.
Remco
vegardkjer
what wcs version have you installed?
what kind of server are you installing wcs on?
mark.cronin
Level 2
Level 2
Remco
I am getting the same error as you, I am trying to install WCS 4.1.91.0 on to a
Windows 2003 SP1 HP Blade Server
4 gigs RAM
20 gigs Harddrive
This is an extract from the wcs-0-0.log file
Can anyone help???
9/20/07 14:37:03.671 INFO[general] [10] Checking for Port 21 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for Port 8456 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for Port 8457 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for Port 1299 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for local Port 1299 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for Port 6789 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for local Port 6789 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for UDP Port 69 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for Port 8005 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for UDP Port 162 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Checking for Port 8009 availability... OK
9/20/07 14:37:03.687 INFO[general] [10] Starting RMI registry on port 1299
9/20/07 14:37:04.62 INFO[general] [10] Registry started.
9/20/07 14:37:06.484 INFO[general] [10] Starting database server ...
9/20/07 14:37:09.437 INFO[general] [10] Database server is running.
9/20/07 14:37:09.984 INFO[general] [10] The database is not properly initialized.
9/20/07 14:37:09.984 ERROR[general] [10] Cannot run with the current schema. Exiting.
I have the same problem running on a domain controller with version 2003 SP2. I've been told that it may be an issue with the type of server its installed on, i.e. try non-domain controller. Will try this asap and let you know.
mathewvdh
Has anyone come up with a resolution for this issue yet? I am having the same issue installing on a 2003 server SP2 machine.
WCS version is 4.1 Base.
