Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WCS Sanity check
SOrry to ask this guys but I m getting confused with the new licensing and wanted a quick sanity check.
Deploying WCS with MSE for location and IDS.
I will need the WCS Plus license only no need for the location license as this is potted with the MSE license? Licensing is getting confiusing as it states in one place that MSE location needs WCS-LOC but in another it states WCS PLUS for MSE?
ALSO to add IDS to the MSE the cisco configurator does not allow IDS and location in the dsame MSE?
My confusion is fromn the legacy laocation appliance software? WHich is only for the standalone location applance not the MSE deployment and the configutrator not allowing location and IDS
1 REPLY
Re: WCS Sanity check
I think you will still need the LOC piece. Also make sure you are running the latest code on the larger MSE if you want to run both location and IDS/IPS on the same box. 6.0 supports it.
156
