01-05-2012 07:17 AM - edited 07-03-2021 09:19 PM
When we attempt to reach the WCS we receive this message occassionally,
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
The quick fix has been to reboot the server. This is starting to happen at least once a week now, and seems to be getting worse. No changes were made to the server. This problem just started happening all of the sudden. Help!
Health Monitor is running.
WCS is stopped.
Database server is running
Apache server is running
WCS Version 7.0.220.0
01-05-2012 07:19 AM
Go into the Administration, tab and take a look at the background tasks. There is probably a task, backup I would think, that is running. Once you see the task that is running at an inopportune time, change it so that it runs at a time noone shoudl be accessing the box.
HTH,
Steve
12-04-2012 12:20 AM
We have been facing similar issue in which the every few weeks we have to restart WCS services. Don't know whats the cause. We are using Version 7.0.172.0
I have checked the release notes for version 172 but couldn't find any caveat.
When WCS is not accessible:
WCS is running
Database server is stopped
After restart of WCS service (StopWCS and StartWCS)
WCS is running
Akhtar
12-04-2012 03:52 AM
If you have to do this every so often, then I would either open a TAC case or upgrade to another version. I would hate to have to do that every other week or so.
01-06-2012 12:25 AM
Kristen,
A known issue with WCS - 7.0.220.0 is because of a crash due to native memory which has been identified as the following bug
CSCtu49966 - WCS crashes due to native memory error in 7.0.220.0
The workaround for this issue is to enable Escape Analysis in the JVM. How to do this is
outlined in the WCS 7.0.220.0 Release Notes at http://tools.cisco.com/squish/3202f .
Essentially, Stop WCS, edit the startServer.bat/startServer.sh file (Windows/Linux)
appending "-XX:-DoEscapeAnalysis" (no quotes) to the set JAVA_OPTS line, then restart WCS.
Ram.
