WCS time settings not correct
We have an issue with the time setting in the GUI of the WCS. The box is set with the right time but in the web interface, the time is set 4h in advance.
The controller is also a the right time.
Silver
Re: WCS time settings not correct
I'm having the same issue. The time on the box which the WCS is running has the correct time but my WCS software is off by 4 hours.
I don't see any way to configure via the GUI.
Is this a bug?
Thanks in advance.
All responses will be rated.
Hall of Fame Super Red
Hi Paul,
I'm not sure if this is the exact issue you are seeing, but I remembered reading this Great answer from Dan Campbell regarding WCS Time;
Make sure in your /etc/sysconfig/clock file the first line looks like:
#ZONE=UTC
Without the # sign in front of this line the server will UTC regardless of how you configured the timezone.
Hope this helps!
Rob
Silver
Hi Rob,
Thanks for the reply. I should have mentioned that I am using a Win2003 box to run the WCS software.
I believe Dan Campbell's answer applies to a Linux or Unix box as I couldn't find the directory he mentioned in Win2003.
Paul
Silver
We fixed the issue by setting the time via the CLI on each controller.
We had been seeing an incorrect time on the Controllers when we were monitoring them through the WCS.
It appears you cannot set the timezone when you create a NTP template on the WCS. If I am mistaken someone please correct me.
Thanks in advance.
193
