Community Member
WCS v4 and WLC v3
Can you use WCS software release 4 in conjunction with controllers running version3 code? This is an issue because we have 4100 controllers that do not have the ability to upgrade to the version 4 release of controller code.
Re: WCS v4 and WLC v3
Yes, support is for N-1. So you can have a WCS runnign 4.x and have it manage controllers in the 3.2 code. But you do have feature/config differences between the two, so some templates may not push to the 3.2 controllers.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Community Member
Thanks for the reply. I found out through TAC that you are right, but some of the features such as lobby ambassador specifically need the version 4 code on the controller to function. Even though lobby ambassador is managed through WCS.
125
