Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
WDS on 802.11b only (AIR-AP1230B)
Aironet AIR-AP1230B
IOS: c1200-k9w7-tar.123-7.JA2
Radius: Local Radius Server (using port 1812,1813)
Key Mngt: WPA and CCKM
Encryption: TKIP
Authentication: LEAP, EAP-FAST
Im getting an error
*Mar 1 00:22:57.083: %LEAPCL-3-TIMEOUT: AP Timed out authenticating to the WDS
although all of my configurations are correct. See below:
ersion 12.3
no service pad
service password-encryption
hostname Cisco1200AP
enable secret 5 $1$i3xO$lgLEzX870FNzgU0n6SRWl.
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
server 192.168.7.131 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius client
aaa group server radius infrastructure
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login method_infrastructure group infrastructure
aaa authentication login method_client group client
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid ciscotrends
authentication open eap eap_methods1
authentication network-eap eap_methods1
authentication key-management wpa cckm
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
broadcast-key change 86400
ssid ciscotrends
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
channel 2462
station-role root
dot1x reauth-period server
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.7.131 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
nas 192.168.7.131 key 7 104D000A061843595F
group registration
eapfast pac expiry 10 grace 5
ssid ciscotrends
block count 10 time 5
reauthentication time 86400
user user1 nthash 7 06562D741B682B3853314B535F557879750E6B67774051345150777F0F02725A5A group registration
user user2 nthash 7 11593B504034292D520C727C7B62677042214E5154050F7A01052F254F477F0C0E group registration
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.7.131 auth-port 1812 acct-port 1813 key 7 14141B180F0B7B7977
radius-server timeout 30
radius-server vsa send accounting
control-plane
bridge 1 route ip
wlccp ap username user1 password 7 12090404011C03162E727D
wlccp authentication-server infrastructure method_infrastructure
wlccp authentication-server client mac method_client
wlccp authentication-server client eap method_client
wlccp authentication-server client leap method_client
wlccp authentication-server client any method_client
wlccp wds priority 255 interface BVI1
line con 0
transport preferred all
transport output all
line vty 0 4
transport input all
line vty 5 15
transport input all
end
Any possible solutions to run WDS on 1230B AP?
1 REPLY
Re: WDS on 802.11b only (AIR-AP1230B)
Just found the cause of error.
I just delete the User Group created on Security -> Local Radius Server -> General Setup
337
