wep and dhcp with ap 350
I have a problem and cannot access to the dhcp server when i configure wep encryption . Do i have miss something with wep configuration? Thanks
Beatrice
Anonymous
N/A
Re: wep and dhcp with ap 350
Are you using WEP key rotation? If so, disable it and see if it works with only one wep key.
Many thanks but i do not use wep key rotation. What can i do ?
I dont know the term used of rotation but I had a simular issue when I have transmit on one WEP key set the transmit on key two on the client (non cisco card) It resolved it self when I had AP and Client transmit on the same key.
Green
Are you using VLANs?
What version of firmware are you running? (APs and clients).
-Scott
123
