02-26-2007 02:04 PM - edited 07-03-2021 01:42 PM
I have a WLC 4400 running ver 3.2.150.6. The LAP is a 1242AG-A-K9. I am getting this error message on the wireless controller log when I try and use my Symbol 9060 RF units the message is:
WEP Key decrypt error. Station MAC Address is 00:a0:f8:ba:b5:36, Base Radio MAC is 00:19:a9:0f:d7:90 and Slot ID is 0.
My setup is WPA using 802.1x and the units do authenicate but then after a random period the users lose their sessions. Actually doesnt seem to matter whether I am using WPA or WEP, i still drop. I havent had this problem with the fat APs. Any ideas?
02-26-2007 07:19 PM
I don't think the WEP errors have anything to do with the client connection drop. The time stamp on the controller and the connection drop you notice on the client will prove this fact.
Please check if there are coverage holes in your network and also verify the RF environment for interference. I would suspect the clients too - check with Symbol if there is any problem with that particular batch or firmware.
02-28-2007 03:17 PM
Some Symbol handhelds want the dynamic WEP key fed to them via Slot 3. Be advised you have to disable/enable all WLANs before doing so.
config advanced eap key-index
03-01-2007 09:53 PM
Cisco is saying the WEP error is a known bug and its a fake message, so that is probably not what is causing the drops. When the clients first started dropping I also noticed another error message but it hasnt show back up till today when i put more client guns back in use. the error is:
WPA MIC Error counter measure activated on Radio with MAC 00:19:a9:0f:bd:80 and Slot ID 0. Station MAC Address is 00:a0:f8:d2:34:98 and WLAN ID is 1.
Any thoughts?
