What are the Cisco 1300 series Antenna Alignment options?
jduin4msu
I am wondering if there are any options for aligning the antennas other than RSSI LED indications.  The cisco aironet is going to be on top of a 10m tower and the lights will not be visible. Is there any way to configure them to an audible output that would increase in loudness or pitch when the signal was strongest?
Vinay Sharma
Level 7
Level 7
Check this:-
"Best Practices" for positioning Access Points (AP's) and Antennas
https://supportforums.cisco.com/docs/DOC-16627
thanks,
Vinay
Thanks & Regards
