What cause the ping lost
I use aironet br342 with 2.4dBi dipole as access-point.
I found that when I use ping -t with a pc ,
over 10 packets time out from time to time , while the signal noise rate is still quite good .
Further more , I found that when I open about clients
the speed of the network became rather slow ,the collision
became unacceptable.
Please be kind to help me, it is urgent.
Re: What cause the ping lost
Little hard to say from the information here but.
Does the client stay associated ? The log of the BR342 will help you check this
On the BR342 do you see many CRC errors ? or radio hold offs
Have you tried another channel ?
What firmware version is on the BR342 ?
What NDIS ACU and firmware version are you using on the clients ?
Are you trying to ping the BR342 or a PC behind the BR342 ?
I hope this gives you a few things to look at
Make sure your ethernet connection is set to "autonegotiate" on both sides or manually set to whatever you decide: 100 Mbps/Full Duplex, 10 Mbps/Half Duplex, etc.
285
