What do IPSEC mean under Security -> AAA -> Radius -> Authentication
I can't find exact information regarding the IPSec checkbox in Security -> AAA -> Radius -> Authentication.
On the Cisco Wireless LAN Controller Configuration Guide 5.1, it says "Check the IPSec check box to enable the IP security mechanism, or uncheck it to disable this feature.
The default value is unchecked."
What is exactly mean by IP security mechanism?
Does this mean that I can terminate VPN client over my WLC?
Take note that this options appeared even though no crypto card installed in my controller.
Re: What do IPSEC mean under Security -> AAA -> Radius -> Authen
This is old code from the Airespace days. There used to be a VPN module that would ride in the WLC. No longer supported, well can't buy it new, but if you had one already...you get the idea.
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Thanks steve.
144
