06-26-2008 08:27 AM - edited 07-03-2021 04:05 PM
Looking at the ISO software for the 1100AP it's a bit had to tell what the latest version of software is. Is it based on the highest position in the directory tree or the highest letter. At the top of the tree is 12.3.8-JEB(GD) yet letter wise if you look further down the tree I see a JEC. Which one is newer or the latest.
Thanks!
Solved! Go to Solution.
06-26-2008 10:42 AM
general deployment versus
ED ( early ) or LD ( limited )
http://www.cisco.com/warp/public/417/109.html
06-26-2008 10:00 AM
12.3.8(JEC) is 5 months newer and both are GD.
Take a look at the release notes and see if their any outstanding issues w/JEC and what might have been fixed from prior versions.
Take a look at 12.3.8(JEC1) which is LD and see if it talks about fixes from JEC.
12.3.8(JEC) looks fine
but if whatever you are on now works ... ???
06-26-2008 10:37 AM
Sounds good. I'll go with the JEC
2.3.8(JEC) is 5 months newer and both are GD. I'm assuming GD means good. Not sure if this is code for a type of software. I couldn't find the JEC1 so I went with the JEC.
Thanks!
06-26-2008 10:42 AM
