What is the Snmp OID for all the MAC addr on the AP ?
amitubale
Whats the OID to to get all the MAC address of on the nodes associated ?
For example, if 4 nodes are connected how do i get thier MAC address.
I have the OID for find the number of nodes associates to a AP
(1.3.6.1.4.1.522.3.12.1.8.0).
I want to use that to find stolen laptops, on the university campus.
Presently use the log files on the syslog server to do that.
Is ther a more efficient way ?
9 Replies 9
kmarrero
Level 4
Level 4
Try these OID's.
.1.3.6.1.4.1.522.3.12.5.1.1
awcDot11TpFdbAddress OBJECT-TYPE
-- FROM AWCVX-MIB
-- TEXTUAL CONVENTION MacAddress
SYNTAX OCTET STRING (6)
DISPLAY-HINT "1x:"
MAX-ACCESS read-only
STATUS Current
DESCRIPTION "A MAC address for which the bridge has
forwarding and/or filtering information."
(2)
.1.3.6.1.4.1.522.3.12.5.1.2
awcDot11TpFdbAID OBJECT-TYPE
-- FROM AWCVX-MIB
SYNTAX UInteger
STATUS Current
DESCRIPTION "AID with which the Station is associated with this
system, or 2008 if the
Station is not currently known to be associated. If the
entry is multicast, awcDot11TpFdbAID is 0. Note that
the uplink from a Client or Repeater AP to its parent
is always AID 1."
I tried those OIDs but it did not return any values.
I have done SNMP walks on the APs and found out that clinet node MAC addr are not on the consecutive OIDs.
for example one of the nodes I saw on the web page and ten tried to look it up in the snmpwalk was
.iso.3.6.1.2.1.17.4.3.1.1.0.7.14.179.132.193
and other one was on
.iso.3.6.1.2.1.17.4.3.1.1.0.2.45.88.1.136
Its very time consuming to search for a node in a environment of @ 600 APs usinf snmpwalks. To reduce the search time the script only does a snmapwalk with the OID .iso.3.6.1.2.1.17.4.3.1.1.0 and look for the desired node.
Is there a better way to find the MAC sddr of the accociated nodes ?
Hi !
I think kmarrero said this:
snmpwalk 172.16.11.2 public .1.3.6.1.4.1.522.3.12.5.1.1
I am using snmpwalk to get the MAC addresses.
What I have noticed is that even if ther are only 10 nodes assoicaited, the snmpwalk returns a huge list. For example, AP with 10 nodes on it gave me a list of more than 30 MAC address.
Do you know why ?
If the other MACs are of reapeater, bridges and APs then, how do I get the list of clients on the AP's management web page ?
Amit
Amit
Hi!
This could help to decide if the mac address is client or repeater etc.
snmptable -M /root/.snmp -m all 172.16.11.2 public awcTpFdbDdpTable
I tried the above command, but I get a error
"Must have exactly one table name"
This is the command. ( dont mind me, I am using Windows snmp, the one on linux is not working , it gives a "snmp timeout")
C:\>snmptable -M C:\Desktop\Cisco\Firmware\MIBS\ -m all 192.168.0.9 public awcTpFdbDdpTable
Then I tried using the OID.
snmptable all -m 192.168.0.9 public .1.3.6.1.4.1.522.3.12.4
same error.
Hi!
I can't understand why! I try windows snmp!
Szicsu
Hi!
What do you use to snmp? What kind of toolkit?
Szicsu
Hello Szicsu,
I am using UCD-SNMP pacakage for windows.
On my Linux system the all the snmp application give a snmp timeout. But the Net::SNMP in perl works fine.
Therefore when you write a command for me to try, I use the Windows ucd-snmp package.
Amit
