Community Member
What's Missing?
no service pad
service password-encryption
hostname WirelessN
enable secret 5 $1$Xlx.$p9k7g168kCt4I8SQiZS.y0
aaa new-model
aaa authentication login default local
aaa session-id common
ip domain name nua.com
ip ssh version 2
dot11 ssid nuaWireless
vlan 30
authentication open
guest-mode
power inline negotiation prestandard source
username cisco password 7 030752180500
username ngarciait password 7 03080B1D5503715A1D
username scurry password 7 110A0C17131D0C5456
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid nuaWireless
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.1
encapsulation dot1Q 30
no ip route-cache
shutdown
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface GigabitEthernet0
ip address 10.1.1.15 255.255.0.0
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0.1
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.1.1.10 255.255.0.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner motd ^C
You Will Be Prosecuted For Unauthorized Access
^C
line con 0
password 7 104D580A0647
line vty 0 4
password 7 020555480856
transport input ssh
end
I'm trying a basic setup here. I created an SSID, bound it to a VLAN, created an ethernet sub interface and a radio dot11 sub interface, both have the same encapsulation, and both are under the same bridge group. I have open authentication. I can authenticate and associate, but I can't pass traffic.
I tried adding the SSID under the radio to bridge-group 2 as well and I get this error:
Configuration of vLAN subinterfaces and main
interface within the same bridge group is not permitted
Not sure what that means.
2 ACCEPTED SOLUTIONS
Silver
Re: What's Missing?
When using subinterfaces, you won't use a bridge-group on the physical interfaces. You should also be using bridge-group 1 on whatever VLAN your management interface is on. This is why you use BVI1 as opposed to, say, BVI2. BVI1 oversees bridge-group 1.
Try the following config:
int dot0.1
bridge-group 1
int gig0.1
bridge-group 1
That should eliminate bridge-group 1 from the interface and replace bridge-group 2. Make sure it does that.
What is your switchport configuration? I assume that VLAN 30 is your native VLAN. If not, your configuration is correct. If it is, you should add the "native" keyword to your config:
int dot0.1
encapsulation dot1q 30 native
int gig0.1
Also, activate your dot0.1 with the "no shut" command:
int gig0.1
no shut
If that still doesn't work, please post your updated config as well as your switchport configuration. Thanks!
Jeff
Silver
Re: What's Missing?
There was another topic a while ago where someone asked about some of these concepts. Read through this thread if you have a few minutes:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=WLAN%20Radio%20Standards&topicID=.ee6e8c2&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd4a100
You only ever need one BVI interface, and this is traditionally the interface that you place the IP address on. The problem with using an IP address on either the Gig or Radio interface is that the AP becomes unreachable if you shut one of them down. This is rarely an issue with placing the IP on the Gig interface since you likely lose power to the AP if it becomes shutdown. But most implementations use the BVI1 as your management interface.
Each SSID has its own VLAN, and each VLAN gets its own pair of subinterfaces (radio and gig). The number used for the pair doesn't matter (could be dot0.1 and gig0.11 if you want...), what matters is that they're on the same bridge-group and have the same VLAN assigned to them.
Now, you're using an access port on your switch, so you actually shouldn't be using subinterfaces. Subinterfaces imply trunking, and the AP will think it's connected to a trunk if you use them. You can still use them if you configure them to use VLAN 30 natively, which means that no tagging will be used (allowing it to talk to your access port). But the best thing to do would be to wipe out the subinterfaces and place bridge-group 1 directly on the physical interfaces.
If you want to configure multiple SSIDs, you'll need to create a new pair of subinterfaces for each one as described above. Make sure you match the native VLAN with what's on your switch config (defaults to VLAN 1 on the switch). Additionally, bridge-group 1 should always be used on your native VLAN subinterfaces. Traditionally, the bridge-group number will match the VLAN number (which traditionally matches the subinterface number). This keeps things clean and easy to read when the number on these three config lines match each other (other than the native using bridge-group 1).
Sorry to make things so complicated. One other note based on your example config in the above post, but SSIDs are never configured for a bridge-group. They are matched to the bridge-group via the VLAN. So configure it like this:
SSID TEST
authentication open
vlan 40
int gig0.40
encapsulation dot1q 40
bridge-group 40
int dot0.40
bridge-group 40
Again, using "40" for everything makes it clean and easy to read. You'll then need to configure your switchport as a trunk (with VLAN 30 as native):
interface gigX/X
switchport encapsulation dot1q
switchport mode trunk
switchport trunk native vlan 30
Make sense?
Jeff
Silver
Re: What's Missing?
int dot0.1
bridge-group 1
int gig0.1
bridge-group 1
int dot0.1
int gig0.1
int gig0.1
no shut
Jeff
Community Member
Re: What's Missing?
So what happens when I have multiple SSIDs?
If I were to add another SSID and VLAN, I would have:
SSID TEST
VLAN 40
Bridge-Group 3
int Gigabit 0.3
int dot0.3
All of this of course being under bridge-group 3.
Is this correct? Would I need another BVI interface for this?
I don't seem to quite understand the function of the BVI interface.
Right now, I have an IP address assigned to the actual gigabit 0 interface and it's what I use to SSH into my AP, instead of using the BVI interface's IP address.
As far as my switchport goes, I have it set as a regular access port on VLAN 30 because I'm only using one SSID or VLAN on the access point. I know if I wanted to pass more VLANs I would have to turn the switchport into a trunk, right?
Silver
Re: What's Missing?
SSID TEST
authentication open
vlan 40
int gig0.40
bridge-group 40
int dot0.40
bridge-group 40
interface gigX/X
Make sense?
Jeff
Community Member
Re: What's Missing?
Exactly that I needed. Thanks for all your help and for your time, Jeff. Very much Appreciated.
-Nelson
Silver
Re: What's Missing?
No prob! Feel free to post up if you run into anything else :)
Jeff
199
