where can get the developer's reference for aironet 350?
I can hardly find anything about using aironet wireless card.
Re: where can get the developer's reference for aironet 350?
Depending on what information you want you have a couple of options.
If you just need information on using the card etc then please check here
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350cards/windows/index.htm
If you want to write your own applications intergrated with Cisco Products then you will need to contact your account team unless it is for a product listed in the developer support program found here ( Aironet is not listed)
http://www.cisco.com/warp/public/570/
I just want to read/write data to the flash on aironet lmc352 card.
But I have no information on that.
The ACU from Cisco does't support read/write user data to the flash.
Can anyone help me?
T.I.A.
What you want to do is not supported by Cisco.
If require this information to intergrate into an application then you need to be part of the developer support program please contact your Cisco Account team to find out further information on this program
112
