Where is the RSSI info between 1500 AP's?
Just wondering where in the WLC you can determine the signal strength between 2 1500's?
Silver
Re: Where is the RSSI info between 1500 AP's?
RSSI should be -74 dbm between neighboring devices.
On the wireless controller the following command will show Snr-Up, Snr-Down and aggregate Link-Snr.
(Cisco Controller) >show mesh path
rgds
Carlo
Gold
A good way to determine how well the 1500's are seeing each other is with the remote AP debugs. These will show you the SNR for an AP that is or isn't joined to the controller yet which is good in troubleshooting why a MAP won't join.
The commands to run them are:
debug ap enable
debug ap command dumpAdjs()
Whats classed as a good link SNR as far as the cisco 1500's are concerned? don't you need a RSSI value and a Noise value to determine SNR?
263
