08-17-2003 11:11 AM - edited 07-04-2021 08:57 AM
dear friends
which 1200 series 802.11b AP should i go for
AIR-AP1220B-A-K9 or AIR-AP1230B-A-K9
well i guess it looks same but, notice the 30 in the second option.
thanks in advance
08-21-2003 03:32 AM
The 1220 uses the origianl VxWorks firmware, the 1230 uses the newer IOS based firmware. The 1230 supports a few additional features and will be developed going forward. So if you want WPA or Cisco Structured Wireless-Aware Network then you'll need the 1230. VxWorks firmware is upgradeable on the 1200 series.
10-10-2003 11:46 AM
Does this mean that the 1220's we have upgraded to IOS are hardware limited and will not support the Cisco Structured Wireless network, or does this just mean VxWorks will not support it?
11-09-2003 02:35 PM
Newer features are being supported in IOS only, so long term you'll want all your 1200's on IOS.
The 1200 hardware is the same whether you are running IOS or VxWorks -- The different SKUs just determine which OS ships on the AP.
You can convert VxWorks to IOS by running a 1-time converter program. There isn't a method to go backwards from IOS to VxWorks.
12-30-2003 07:18 AM
no, a upgraded 1220 (VxWorks) system to a IOS is technically considered a 1230 AP from then on out, just on the back of the unit, it will still say 1220.
I also confirmed this with the TAC.
